Heatbed LED not working and frayed wires
Rob2D
(@rob2d)
Hey all,
My heatbed LED wasn't coming on so I decided the take the cover off the lead to investigate. LED looks fine but as you can see below the connection on the left seems to have split and frayed a bit. Could this be the cause? The bed heats up fine so I'm just wondering if I should solder up that wire while I have the cover off?
Postato : 18/07/2017 1:49 pm
Knickohr
(@knickohr)
Utenti Moderator
Re: Heatbed LED not working and frayed wires
This is not really a probem.
Resolder the wires and it's OK again, but this does not solve the problem with the LED. The LED is maybe blown. Can you exchange it ?
Thomas
Postato : 18/07/2017 2:17 pm
JeffJordan
(@jeffjordan)
Utenti Moderator
swap the wires, most likely that the polarity has been mixed up.
for simple heating the polarity isn't relevant... but for the LED to light up.
anyhow: fix the issue with the frayed wire ends ! because the heatbed draws about 15 amps, every little bit of wire is required.
maybe this is a good time to replace the whole cable with a new one @ 2.5mm² conductor cross-section.
Postato : 18/07/2017 2:32 pm
Rob2D
(@rob2d)
Yup, that was it! Put a bit of solder on that wire for now. We have lots of reels of wire at work so should be able to find something suitable for a replacement.
Thanks for the knowledge 😉
Postato : 18/07/2017 6:51 pm
slippyr4
(@slippyr4)
14 AWG silicone insulated wire would be a good choice.
Postato : 18/07/2017 7:56 pm
JeffJordan
(@jeffjordan)
Utenti Moderator
hmmm... quite at the edge with the 14 awg. if I had the choice, I would go for 12 awg.
2.5mm² metric would be just in between both imperial gauge sizes... so 13 awg would be perfect :mrgreen: .
Postato : 18/07/2017 10:08 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Yeah, I used 2.5mm^2 speaker cable. Bit stiff, but it's been working for almost 12 months.
Peter
Postato : 18/07/2017 10:12 pm
