Glass over PEI
ZARIBO
(@zaribo)
Glass over PEI
Hello, please do not try to praise PEI sheet in first 🙂
I have tried to print an ipad case and those two screws in the middle of the heated bed had created to swells on the back of the case.
I am just asking if it is possible to give 2.5mm ofset to the probe in order to print on glass? There is a method to add a script in the slicer to the top of the gcode and make the extruder pause for a minute after bed leveling. Then you put on the glass.
But I do not want to add script and add remove the glass every initial print.
Many thanks for your help.
Napsal : 26/01/2017 7:35 pm
David T.
(@david-t)
Re: Glass over PEI
Type of probe used on MK2 will not trigger at that heights. You would have to use different type, probably one of 12mm probes. I don't know any 8mm probe capable of trigger height above 2mm.
Napsal : 26/01/2017 8:24 pm
ZARIBO
(@zaribo)
Re: Glass over PEI
some say it has 4mm range.... thats what I am curious about.
Thanks for the reply.
Napsal : 26/01/2017 8:26 pm
richard.c12
(@richard-c12)
Re: Glass over PEI
Yes I know you have to program in the pause, but in case you have not seen it.
Napsal : 27/01/2017 9:30 pm
ZARIBO
(@zaribo)
Re: Glass over PEI
I have seen it, and trying to figure out bed leveling with the glass 🙂
Napsal : 27/01/2017 9:37 pm
