Full RX Buffer
defsdoor
(@defsdoor)
Full RX Buffer
Have had this twice now - printing from octoprint -
Send: N84475 G1 X68.203 Y137.091 E0.03464*95
Recv: ok
Send: N84476 G1 X68.805 Y136.239 E0.03529*89
Recv: Full RX Buffer
Recv: ok
Send: N84477 G1 X69.348 Y135.319 E0.03617*85
Recv: ok
Send: N84478 G1 X69.852 Y134.345 E0.03712*86
Recv: ok
Send: N84479 G1 X70.563 Y132.810 E0.05725*95
Recv: Error:Line Number is not Last Line Number+1, Last Line: 84475
Recv: Resend: 84476
Recv: Resend: 84476
Changing monitoring state from 'Printing' to 'Operational'
Any idea what the problem is ?
Veröffentlicht : 24/05/2017 10:57 pm
ed.y
 ed.y
(@ed-y)
Re: Full RX Buffer
I've not noticed this Full RX Buffer error but I have seen:
Recv: Resend: 84476
Recv: Resend: 84476
Mine seemed to stop at random times, and when checking the terminal window i saw the above code. I noticed if I click on Pause and Resume Print in Octoprint it will continue printing.
I was never fully able to confirm what caused it, but from my testing it only ever seemed to happen when I cancel a print by canceling either on the printer or via Octoprint. It seemed like when the print is cancelled OctoPrint takes I while to catch up.
What I do now is I've set a Cancel Print Script in Octoprint to move nozzle out of the way and also to play a buzzer sound at the end. When I tested this a few times I did notice Octprint sometimes would take a few minutes for the buzzer to sound, signalling the cancel print has completed.
I think before I put this script in I would start a new print before the cancel process had stopped, which probably causes some buffering issue, but that is just a guess
Veröffentlicht : 25/05/2017 9:34 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Full RX Buffer
There is a fault within the firmware such that the printer does not send an "ok[" when it should.
There is a work-around built into OctoPrint:
Settings/Serial Connection/Advanced Options/Simulate an additional "ok" for resend requests - put a tick in the box.
Peter
Veröffentlicht : 25/05/2017 10:23 am
