fist layer after raft is thick!
kiyoung.k
(@kiyoung-k)
Hello
I've purchased my first printer and have been testing it in different ways.
Recently I've found an issue about the first layer height after a raft layer.
As you see it in a screen shot of a preview of prusa sli3er, the thickness of the first layer after the raft is set too thick.
I made turn-offs and turn-ons to make this not happen :
1.Layers and perimeters - height of the first layer is set equal to general layer height.
2.Support material - contact Z distance is set to 0.01mm
3.Support material - interface layer is set to 0.
But still this unwanted thickness is there.
I wanted to use a single raft layer because soon realized that it is a good way to stick the object safely on the bed and more over, I like it because it makes detaching an object from the bed very easy.
Anyway, result acording to this first thick layer is as a picture attached. Not sure, but I think that incline, or inward offset, is due to the thickness of the first layer.
Does anyone know how to fix it?
Thank you.
Publié : 05/10/2017 10:13 am
