First Layer problem - Z calibration?
javier.c3
(@javier-c3)
HI there
I'm new Here my name is Javier and I'm from Argentina.
I'm trying to iron out some issues with my new prusa (kit) and I'm kinda lost with this problem on my first layers.
I've printed the 75x75 test file and this is the result I get.
Any one can point me in the right direction on why I get those wierd gaps ?
Thank you so much
Opublikowany : 02/03/2017 1:21 am
Re: First Layer problem - Z calibration?
Hi Javier.
you could try increasing the negative number of the live Z adjustment a little...
above is a picture of my test print taken tonight,
The front left, middle left and rear left squares are overly squashed so I think I can reduce the live Z adjustment slightly
you can just see the characteristic ripples in the front left square, in the picture.
this was accompanied by surface roughness.
Opublikowany : 02/03/2017 1:52 am
