Firmware 3.0.12 FINAL - MK2 Multi Material, MK2/S & MK1
Jakub Dolezal
(@jakub-dolezal)
Member Admin
UDPATE: There is a newer version of the firmware, though keep in mind it is beta https://shop.prusa3d.com/forum/original-prusa-i3-mk2-f23/firmware-3-1-0-rc1-mk2-multi-material-mk2-s-mk1-t6112.html
Hi guys,
This is the final version of initial firmware for Multi Material Upgrade. Besides the support of Multi Material print, we've improved Selftest, XYZ calibration and added XYZ calibration details in the printer's menu.
Changes compared to the 3.0.12-RC2:
Multi material colorprint - fixed bug with active beeper during filament loading
M500 G-code now doesn’t store Esteps value to EEPROM preventing weird behavior when upgrading MK2 to MK2 MM
Supported printers:
This firmware supports MK1, MK2/S, as well as their Multi Material upgraded versions.
Download link: http://www.prusa3d.com/drivers
Updated flashing guide: http://manual.prusa3d.com/Guide/Upgrading+firmware+v1.1/66
Full changelog: https://github.com/prusa3d/Prusa-Firmware/releases
Happy printing!
Assembly manuals
/ Knowledge Base
Napsal : 14/09/2017 11:51 am
mavu
 mavu
(@mavu)
Re: Firmware 3.0.12 FINAL - MK2 Multi Material, MK2/S & MK1
Does this require any action if I previously updated the firmware on MMU upgrade?
Do I need to reset the E-steps or something?
Napsal : 17/09/2017 8:59 am
Jakub Dolezal
(@jakub-dolezal)
Member Admin
just discussed this with the dev and no action is required from the user 😉
Assembly manuals
/ Knowledge Base
Napsal : 18/09/2017 11:01 am
