Filament question
IchBinRooster
(@ichbinrooster)
Filament question
❓ Hello everyone, I'm trying to find which filament was used for a print on the printed models page. http://www.prusa3d.com/original-prusa-i3-prints/
The model I'm trying to find information on is the copper/bronze eagle, not really sure of the exact color. If anyone knows anything about it, that would be awesome. Thank for your time
Opublikowany : 06/01/2017 1:37 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Filament question
If it's the painted griffin model you are looking at, they Roman is a member of these forums - user roman.t
You could PM him to ask.
Peter
Opublikowany : 06/01/2017 9:41 am
JeffJordan
(@jeffjordan)
Member Moderator
the copper/bronze eagle seems to be something like AptoPro's metal- red-copper filament or similar stuff, which is quite expensive.
but simply follow the link to diezeldave on Imgur and send him a message...
Opublikowany : 06/01/2017 12:34 pm
PJR
 PJR
(@pjr)
Ah. Just seen the one.
I believe it's this filament: http://shop.prusa3d.com/en/filament/76-copper-pla-filament-1kg.html
I use that and it does look good.
Peter
Opublikowany : 06/01/2017 12:44 pm
IchBinRooster
(@ichbinrooster)
Thank your for he replies. I had tried to contact him previously however got no response.
Do you know of any similar filament from another source? The filament in the link is out of stock, and I have some prints I need to get I need to process. They picked the color from the pictures and not the filament page. Plus shipping is around $32 for the $22 spool if it comes back in stock.
Opublikowany : 06/01/2017 1:42 pm
IchBinRooster
(@ichbinrooster)
OK so I've stumbled across the information I was searching for. The filament is Gizmo Dorks Copper Fill.
Here are a couple links.
The first is the web page I found the information on.
https://www.reddit.com/r/3Dprinting/comments/4wmnr5/25_mm_nozzle_on_prusa_i3_mk2/#bottom-comments
The second is a link to the amazon page with the filament.
https://www.amazon.com/Gizmo-Dorks-1-75mm-Filament-Printers/dp/B01CV49CZQ/ref=sr_1_2?s=industrial&ie=UTF8&qid=1484103889&sr=1-2&keywords=gizmo+dorks+copper
Thanks for everyone's help with this.
-John
Opublikowany : 11/01/2017 4:18 am
Carsten
(@carsten-2)
I think Prusa should call it "Coper Colored Filament".
The Amazon link is "proper" coper filled(!) (5%).
Carsten
My Prints: https://www.prusaprinters.org/social/15695-carsten/prints
My Employer: https://make-magazin.de
Opublikowany : 11/01/2017 10:32 am
