Filament Change
cory.w
(@cory-w)
Filament Change
Anytime I perform the filament change command using the LCD display, I load the filament as normal. But after confirming the color is coming out clean, it stays there a minute, pushes out a few mm of filament, and travels back to print. I have to quickly grab the filament off or it usually creates a bleb on the print.
Is this normal or is the filament change code messed up for some reason?
Veröffentlicht : 08/03/2018 2:47 am
Re: Filament Change
Hi Cory,
this is just... what happens.. 😯
Sooooooo....
grab the waste with your long nose pliers, press the button, and the extruder will go about it's business, leaving all of the waste attached to your pliers.
Veröffentlicht : 08/03/2018 3:17 am
cory.w
(@cory-w)
Re: Filament Change
This really sounds like a coding issue. Why would this be a feature if the filament is already at the tip upon approval the color is clear?
Veröffentlicht : 18/04/2018 2:22 am
Re: Filament Change
Nobody said it was a feature. Its just what happens and how to deal with it.
If you make the nexessary code changes. And publish them... The whole open source movement would be pleased to benefit
Regards Joan
Veröffentlicht : 18/04/2018 3:05 pm
