Failed Bed Leveling
genel.j
(@genel-j)
Failed Bed Leveling
Attempting to run the bed leveling and the first 2 areas it levels is fine, however when it gets to the third spot I get an error with 'Bed Leveling Failed. Sensor didn't trigger.' Does anyone know what might cause this and any solutions for this issue?
Publié : 08/10/2017 2:06 am
AJS
 AJS
(@ajs)
Re: Failed Bed Leveling
That is typically cause by one of a few things:
1) Your PINDA sensor is too high and is not triggering. Lower it.
2) Your bed is not level - head it too far away in parts of the bed and closer in other. - Square up your build.
3) The head is searching in the wrong place because the X or Y belts are loose and skipping steps.
You might find this post helpful:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/-before-you-ask-troubleshooting-video-updated--t472.html#p39190
Publié : 08/10/2017 6:12 pm
