Extruder delivers not enough filament
Hi all,
after a whole day trying to get my prusa MK2 back to work after a horrific print last month I guess I need your help.
What had happened:
- Print went bad
- All filament got up into the Extruder assembley
- a lot of heat was introduced
- most parts are OK so far
What I did
- Disassembled the Extruder and Wiring
- Cleaned the nozzle mechanically
- Reassembled the Extruder
- Selftest OK
- XYZ Calibration OK
- burned off remaining filament (That wasn't fun!), even my smoke detector went off
- everything looks good so far
And now I try to get the "V2Calbration.gcode" printed
What the problem is:
It looks like there is not enough flow of filament to create a solid line on the print bed.
- Loading / Unloading of filament works fine
- Manually feeding or removing the filament works fine
- I checked the wiring of the extruder motor for damages
- I even wrote a gcode file to turn the motor while I moved the wires - no issues, Extruder Motor is OK
- I checked the tension of the springs of the idler (13-14 mm)
- I tried a 2nd spool of PLA Filament
- White filament comes out perfectly white (before I printed in black)
- I installed the current firmware 3.0.10
- I loaded the current version of the V2Calibration.gcode from the prusa website and reprinted
- I disassembled the Extruder again, removed, checked and reinstalled the PTFE Tubing
- I checked the alignment of the pulley to the PTFE Tubing
- I checked the pulley for any loose filament remains-  it is perfectly clean and moves the filament fine
- There is no skipping noise of the motor or the pulley
- I pulled the filament manually at 130 °C and this is what it looks like
And still the V2 Calibration I printed many many times is crap!
Is it possible, that I damaged the tip of the nozzle during mechanical cleaning?
If I do not get it back to work, I'll search for a new hobby and I am so desperate that last weekend I played golf already...
Any help appreciated! Thank you!
Re: Extruder delivers not enough filament
Solved,
new day, new motivation...
- removed the nozzle and as expected I was able to look through the little hole
- anyway cleaned again with a 0.3 mm steel wire
- Checked the whole filament path is clean
- reassembled everything
New attempt to print V2Calibration.gcode with the same result.
Recognized the extruded filament looked "overcooked" coming out of the nozzle. Rerun V2Calibration.gcode with significantly lower temperature of 185°C (this filament is given with 180 - 200°C) V2Calibration.gcode standard is 210°C
Had significantly better result and after a small Z Adjustment the result was flawless.
Whoohooo! I am back in business 😀 Solved
And still the V2 Calibration I printed many many times is crap!...
to get the first layer adjustment right with the v2_calibration.gcode, you need to be a lucky guy. 😛
that's why i've looked for a better method, that you can find at this thread.
by the way: did you check the thermistor as well ? it needs to have a very good thermal contact inside it's fitting (needs to be cleaned from molten pla, if there is some).
Did you tighten the two extruder screw enough? if not, the layers won't be good. The two screw should be perpendicular to the x axis(not too tight, but not too loose as well) so the filament can be extruded steadily.
