E3D Block & Sock - V6 Upgrade kit
ayourk
(@ayourk)
I have recently upgraded my 3D printer to the new hotend block. I am hoping that someone that has recently received a prebuilt MK2 could post some detailed pictures of how the thermistor connector fits on the back and underside of the X-Carriage. I think I saw something like this in one of the review videos, but since I didn't start with the new cartridge thermistor, I have no clue how this is supposed to be routed.
Dimensions PNG
and an 8 inch (200mm) or greater caliper is recommended.
Opublikowany : 06/10/2016 6:24 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: E3D Block & Sock - V6 Upgrade kit
Hi Aaron
I did the same a couple of weeks ago and had the same issue. I managed to wedge the cable connector in the groove where the heater cable passes through and the thermistor plug will fit with sufficient slack cable to attach the socks.
Peter
Opublikowany : 06/10/2016 10:39 am
David T.
(@david-t)
I was not that patient, so I cut the connectors and soldered the wires directly, then covered by shrink tube. 🙂
Opublikowany : 07/10/2016 9:32 am
TOTO
 TOTO
(@toto-2)
Have a look at the updated manual:
http://manual.prusa3d.com/Guide/5.+Extruder+Assembly/114
STEP 30 ...
Opublikowany : 07/10/2016 10:05 am
PJR
 PJR
(@pjr)
Thomas
Step 31, option 1. It may be my eyesight, but pictures 2 and 3 appear to show that the connector has been modified a little...
Peter
Opublikowany : 07/10/2016 10:15 am
ayourk
(@ayourk)
I looked at the updated manual, but the photo doesn't show enough detail for me. I think I'll go forward to modify the X-Carriage so that the connector fits inside it.
Dimensions PNG
Opublikowany : 07/10/2016 7:23 pm
