Do buildplate bolts affect heating?
clint.g
(@clint-g)
I'm wondering if the two central bolts in the buildplate of an i3 Mk2 make for uneven heating. I'm getting curl-up. Filament is Taulman In-PLA. Notice that the curl happened in the corner right above the bolt ... and that has been a persistent occurrence.
Any thoughts or experience would be appreciated.
-- Clint Goss
Respondido : 26/11/2017 12:04 am
clint.g
(@clint-g)
Re: Do buildplate bolts affect heating?
So before I start moving all my models around to "avoid the bolts" ... I'm *really* curious: if
* anyone has seen this issue around the bolt locations, or
* has any reason to suspect that this might be an issue, or even
* had done lots of curl-prone prints without every seeing this issue so that I can avoid shifting all my prints ...
Thanks for any thoughts / info you might have!
-- Clint Goss
Respondido : 26/11/2017 6:49 pm
Hi Clint, I have never noticed a problem with the bolts,
it looks like you have a brim on the model, so I would expect that model to stick to the build plate quite well. however, however, it doesn't seem to stick.
it looks quite severe warping, have you tried a lower temperature for the filament on higher layers. ? this may help curb the curling.
you can try moving the print away from the bolts, but I would think that the issue is somewhere else.
have you cleaned the build plate?
could you try turning the model 90 degrees? this may help...
Respondido : 26/11/2017 7:53 pm
clint.g
(@clint-g)
Thanks for the suggestions Joan!
In my particular situation, I have managed to "curb the curling" (sounds like the title for an article ... although the World Curling Federation might take exception). However, I was still interested if bolt-avoidance is warranted, in cases where a *slight* heatbed variation might make the difference between curl or no-curl. Found this thermal image in the Prusa archive of posts (edited to isolate the thermal image for just the Mk42 Heatbed):
... and this does seem to imply that, in borderline situations, bolt-avoidance might be warranted!
Thanks again for the help!
-- Clint Goss
Respondido : 27/11/2017 10:33 am
GertL
(@gertl)
Have you checked that your live z is really squished down properly, and cleaning with Aceton?
I have never heard or considered this myself.
Gert
Respondido : 27/11/2017 10:45 am
clint.g
(@clint-g)
Thanks Gert ... Yes I have taken many steps toward improved HPB adhesion, and am now successful sticking all my prints.
However, I continued with this idea of bolt-avoidance ... which seems to be a *slight* and *minor* issue, but one that might be worth consideration if you're on the limit of adhesion. I think if just one corner is gonna curl, it's gonna be the one over the bolt.
-- Clint Goss
Respondido : 27/11/2017 10:58 am
GertL
(@gertl)
Fair enough.
I have had times of bad adhesion too. In my case it always have been bad cleaning. Going from ABS to PLA really needs a good scrub down in my case..
Gert
Respondido : 27/11/2017 11:58 am
