Design change on the Z axis ?
LaPointe
(@lapointe)
French moderator and translator Moderator
I want to submit something to you to check if I'm not insane...
It seems that the Z axis design has slightly changed, and now the X axis farther from the frame. The main consequence is the the Z axis is hitting the screws and not the plastic part as in the following video when I move the Z axis all the way up:
Is this a change from the "S" version or another iteration? My kit has shipped at the end of June, and I don't think I can have mis-assembled this part since the rods are parallel to the frame...
Postato : 29/07/2017 11:33 am
JeffJordan
(@jeffjordan)
Utenti Moderator
Re: Design change on the Z axis ?
at my mk2 kit that arrived here last november, the z-axis always bumps against the heads of the m3 screws, when reaching the top.
Postato : 29/07/2017 12:52 pm
LaPointe
(@lapointe)
Ok thanks, so this is even pre-S, your reassure me :mrgreen:
Postato : 29/07/2017 1:59 pm
