Damaged hot-end
James Henderson
(@james-henderson)
Damaged hot-end
During an overnight print, the Y axis belt on my i3 mk2S failed. The print continued and filament from the extruder coagulated into a huge blob encapsulating large portions of the extruder assembly. The blob is now solidified and cannot be removed without destroying the hot-end wires and plastic housing. It is likely that the extruder assembly and all associated components will need to be replaced. For example, even though I could detach the extruder motor and PINDA probe, their wires will be damaged during extraction.
I can't find these replacement parts on the Prusa e-Store. Even if they were available, it may be more cost effective to order a new printer kit.
So here's the question: Is it sufficient to order an i3 mk3 upgrade ($499)? Will this include all necessary components to fully replace the hot-end assembly on my i3 mk2S? Or, should I order another i3 mk2S ($599) and scrap my existing unit?
Respondido : 23/12/2017 6:51 pm
Starlynk
(@starlynk)
Re: Damaged hot-end
You can contact support via the shop.prusa3d.com site. They do keep replacements for everything, just some they do not list and only keep for problems like yours.
Respondido : 23/12/2017 7:19 pm
Starlynk
(@starlynk)
Re: Damaged hot-end
Also, I believe Ultimachine.com has those parts as well
Respondido : 23/12/2017 7:20 pm
James Henderson
(@james-henderson)
Re: Damaged hot-end
Thank you for responding. I will contact Prusa support to request a repair parts quotation.
Respondido : 23/12/2017 7:39 pm
James Henderson
(@james-henderson)
Re: Damaged hot-end
I've disassembled as much of the extruder assembly as possible. Attached are additional images of the damaged items. By my reckoning, I will need to replace the E3D V6.1 Assembled Hotend and the ABS parts which encapsulate it.
Respondido : 26/12/2017 1:12 am
James Henderson
(@james-henderson)
Re: Damaged hot-end
I believe I need all of the replacement parts listed here: https://shop.prusa3d.com/en/printer-upgrades/71-original-prusa-i3-285-mm-to-175-mm-mk1-upgrade-kit.html#/11-color-black_printed_parts . Unfortunately, these are no loinger offered.
Respondido : 26/12/2017 1:16 am
