Cura issue. It sees the printer than doesn't. Any thoughts?
ray.f
(@ray-f)
I got my printer today and did a test print of the Prusa logo from the SD card and it worked great. I moved to slic3r to try to print something and it oddly would not find my files. (My fault, forgot they were in zipped files)
Not knowing this I moved to Cura, which printed a test print just fine. I moved to a print of the Eiffel Tower. As soon as I opened Cura, it seemed to cause the printer to reset. The fans shut down, the LCD went blank, and then it all came back. Cura found the printer, but after I started the print, its systems went blank but the printer kept going. I stopped everything and closed out Cura to try again. When I restarted the software, the printer "reset" again.
Is this a common issue with Cura? It happens every time I open a file. While the printer is printing my tower, Cura is again blank. (When I say blank, it's open but no longer receiving temps, etc. from the printer and says no printer detected)
It's not the pc locking up. I can close the software after prints are done.
I'm using Windows 10 and running off a USB cable. Windows sees the printer in device manager. As I just got it today, I'm going on the assumption the firmware is up to date.
I'm open for suggestions. Thanks!
On another note...I can't seem to load..STL files in slic3r.
Publié : 03/02/2017 1:28 am
