[Zamknięte] Creating a spare SD card
ozyreusz
(@ozyreusz)
Hello
I need to create a spare SD card
I used sandisk formated as fat32 and the printer does not recognise it.
I see the SD card inserted message but in menu the is a no sd card message. Empty folder with no file although but i copied a gcode file on it earlier.
How do i prepare a sd card so it is recognized by mk2
Opublikowany : 03/12/2016 11:59 am
mark.o
(@mark-o)
Re: Creating a spare SD card
When I look at my SD card from the Prusa it's just an MS-DOS Fat 32 disk. Nothing exotic.
Opublikowany : 05/12/2016 6:13 am
Lintsi
(@lintsi)
Have you tried to use your operating systems own formatting? E.g. in windows right-click the card --> format --> FAT32.
-Lintsi
Opublikowany : 05/12/2016 6:25 am
charles.l2
(@charles-l2)
Did you ever figure out how to create a spare sd card? I am having the same issue. I have already formatted the card using fat32, but it still doesn't work. I am using a 64gb micro sd. Is there a size limit?
Opublikowany : 07/03/2017 2:39 am
Sorry I have never used a 64GB card,
could you try a smaller card?
my 32Gb seems to work ok!
Opublikowany : 07/03/2017 10:07 am
Knickohr
(@knickohr)
Member Moderator
Mabye Marlin doesn't support more than 32GB.
This is often a limit for card-readers.
Thomas
Opublikowany : 07/03/2017 10:08 am
gabriele.s2
(@gabriele-s2)
I've had trouble with a 4GB card by the way. So I'm not sure if size is the only factor.
- Gab
Opublikowany : 07/03/2017 2:04 pm
JeffJordan
(@jeffjordan)
Member Moderator
😕 hi guys, have you ever calculated how many *.gcode files you could store on such big sd-cards ???
🙄 it's going to be very confusing if you store 50 or more *.gcode files at a single sd-card when you try to navigate through it, using the little lcd console.
➡ personally i prefer small sd-cards, like 512 MB ones... and i can still pack enough files on it to loose the orientation.
Opublikowany : 08/03/2017 12:14 pm
Eric Still
(@eric-still)
I have a 32GB Sandisk Ultra Plus microSD card that works just fine. It is formatted FAT32. I did format it on my Linux laptop, but that shouldn't make a difference.
I do have issues with the MicroSD to SD adapter. My printer and computers will occasionally not recognize the inserted card. All it takes to fix that is to remove the microsd card from the adapter and reseat it.
I know 32GB is overkill, but it was on sale.
Eric
Opublikowany : 08/03/2017 4:41 pm
gabriele.s2
(@gabriele-s2)
Indeed, but the bundled in card is 8GB. 😀
Folders!
I put the bundled Gcode files into their own folders, then I have a folder for calibration files (eg. v2calibration, 1st layer calibration - similar to yours -, etc), and an Archive folder for Gcode that I may want to print again in the future (eg. I have some modular objects where I can print more pieces if I need too).
- Gab
Opublikowany : 08/03/2017 8:28 pm
HoldenArt - William
(@holdenart-william)
I was having this issue. Finally I formatted the SD Card (FAT32) with the "Quick Format" UNCHECKED and that worked!!
Opublikowany : 24/12/2018 2:22 am
1 ludzie polubili
KiwiB
(@kiwib)
RE: Creating a spare SD card
I had issues, with the card reader not working.  Turns out the size of the card was the issue.  64 GB, no go.  32, worked fine.
Opublikowany : 04/08/2019 5:54 am
Garrett Klein
(@garrett-klein)
Not sure if anyone is still having this issue but I was able to get my printer to read my card, 64 gb sandisk, by reformatting it as a FAT32. To format it as this I found a nice piece of free software, link below, that formats any size drive as FAT32. When you follow the link, click "Windows GUI version of fat32format" then click the picture and run the software. So far I have tested this on 4 new 64 gb SD cards by sandisk and all have worked.
http://www.ridgecrop.demon.co.uk/index.htm?fat32format.htm
Happy Printing!!!!
Opublikowany : 11/09/2019 3:07 am
mogh.m
(@mogh-m)
Posted by: @michal-o_1551621334
Hello
I am facing the same issue someone help me out.
mybkexperience
Opublikowany : 20/11/2019 6:50 am
Zoltan
(@zoltan)
Member Moderator
Hi
FAT32 should work without any issue. Just checked a spare SD 4GB card standardly formatted for FAT32.
What is the size of your SD card?
Check please your g-code file extension is correct.
Opublikowany : 20/11/2019 8:22 am
tedwards
(@tedwards)
@william-h14
Thank you for this hint! I was having problems with my 32 Sd card not showing up on the printer but after formatting it on my laptop with the quick format box unchecked, it worked!
Opublikowany : 18/05/2020 10:27 pm
Tankhub
(@tankhub)
Hello
Opublikowany : 21/05/2020 11:11 am
Tankhub
(@tankhub)
Hello I had the same problem as you when formatting with a specialized software under Mac and and it did not work I tried with the Microsoft format of the finder and there it works, I now use an SD card of 128 giga without problem
I have had the best luck using the SD Memory Card Formatter software from the SD Association.
Opublikowany : 21/05/2020 2:51 pm
1 ludzie polubili
