Construction issue when building my i3 MK2
Rob Meades
(@rob-meades)
While building my i3 MK2 I came across two issues with the extruder body:
  • a piece of the "grill" fell off (see right-hand blue circle),
  • while tightening the two parts together a part cracked (see the left-hand blue circle).
  • I have continued with the construction in the hope that the machine will work sufficiently well that I can print replacements. Question is, is this a viable thing to do or should I request replacement parts?
    Rob
    Veröffentlicht : 23/10/2017 12:59 pm
    Criações ao Cubo
    (@criacoes-ao-cubo)
    Re: Construction issue when building my i3 MK2
    Rob
    Same thing happened to me, but mine was broken already in the bag. That tiny bit however doesnt cause any issue, you printer will work the same with ot without it. Dont think a replacment is needed. Not printed one or requested one either. you will be fine 😉
    Veröffentlicht : 23/10/2017 1:11 pm
    Rob Meades
    (@rob-meades)
    Thanks for the feedback. Did you have the "crack" issue (the circle on the left) as well? Just looks as though it might cause some degradation in something or other.
    Veröffentlicht : 23/10/2017 1:41 pm
    PJR
     PJR
    (@pjr)
    Antient Member Moderator
    The part cracking is usually caused by the use of a too long screw (2mm too long); it's a mistake which was quite a common one.
    The part can be welded with acetone.
    Peter
    Veröffentlicht : 23/10/2017 2:49 pm
    Rob Meades
    (@rob-meades)
    Thanks: PRUSA have just come back to me and said they'll send replacement parts so I think I'll play safe and wait for those to arrive.
    Veröffentlicht : 23/10/2017 3:00 pm
