Changing to new spool mid print causes extruder to extrude really fast
pablo.h
(@pablo-h)
So i was printing a piece for over 12 hours and it was time for a new spool.
1 I paused the print
2 moved the extruder slightly to the right (in anticipation for the oozing and small extruded piece loading filament creates)
3 unloaded the filament
4 loaded new spool
5 resume print
6 extruder moves at ludicrous speed which causes print failure 🙁
The order steps 2 and 3 might of been done in different order i forgot. My extruder starts extruding at some crazy fast speed and needed emergency manual filament unloading to prevent a serious clog. I forget about this every time i need to do this and it allays messes up my prints. any way to save the print or a better way to load a new spool mid print?
Any advice would be greatly appreciated!
Pablo H.
Postato : 12/01/2017 10:55 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Changing to new spool mid print causes extruder to extrude really fast
Pable
I guess you didn't use the "Change Filament" menu option?
Peter
Postato : 12/01/2017 11:09 pm
pablo.h
(@pablo-h)
Do you mean the Unload Filament and Load Filament options in the menu? Those are the ones I used, is there a change filament operation?
Postato : 12/01/2017 11:21 pm
PJR
 PJR
(@pjr)
When printing, click the knob, select "Tune" then select "Change Filament".
It is explained in the manual... 😉
Peter
Postato : 12/01/2017 11:23 pm
pablo.h
(@pablo-h)
Ohh nice thanks! 😀
Postato : 12/01/2017 11:35 pm
