Change filament function?
Patrik Rosén
(@patrik-rosen)
Hi!
I'm printing some prices for my wifes bowling after work event tomorrow. Changed color to red, it worked great, but when I was about to change it back to white I loaded the new filament, but when it reached the spot where it was about to continue the print it just stopped...I waited for about 20 seconds before I raised the Z axis and removed my print to restart it, after a while it continued to print, mid air?
I had to choose "filament is not clear" three times when switching from red to white.. are there a timeout when using the change filament function?
Best Regards Patrik
Me on 3dhubs!
Postato : 24/10/2016 7:27 pm
Patrik Rosén
(@patrik-rosen)
Re: Change filament function?
Reprinted!
Same problem again! This time I just choose "filament is not clear" one time instead of three times, but it still stopped when it reached the spot where it should continue... Gaaaah!
I wont touch it now...Lets see if it magically starts again 🙁
Me on 3dhubs!
Postato : 24/10/2016 9:25 pm
Patrik Rosén
(@patrik-rosen)
YES, it just started again! I did pause/resume the print from octoprint a few times, not sure if that helped
Me on 3dhubs!
Postato : 24/10/2016 9:27 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Patrik
Did you check out the Octoprint Terminal window. I have noticed that the M600 causes issues if you take too long (more than 3 beeps) to change the filament, even with the command in "long Running Commands" and an increased timeout.
Peter
Postato : 24/10/2016 10:38 pm
