Black power under printer
coolRR
(@coolrr)
Hi guys,
I'm dealing with a weird phenomenon with my Prusa MK2S.
I recently changed my heatbed, and since then I've been seeing black powder beneath my printer, see pictures:
Any idea what this is and whether I should worry?
Thanks,
Ram.
Opublikowany : 15/03/2018 11:17 am
marco.b5
(@marco-b5)
Re: Black power under printer
Hi guys,
Thanks,
Ram.
That is your y-axis belt slowly disentigrating. You should check the movement on your y axis and either loosen or tighten it. Looks lime loosen it a little.
Opublikowany : 15/03/2018 12:07 pm
alexander.s27
(@alexander-s27)
Also the idler position should be adjusted. R/L
Opublikowany : 15/03/2018 12:50 pm
Nikolai
(@nikolai)
As already mentioned the belt is rubbing against something. Check the whole belt path. Motor - Bed holder - Idler. All of them need to be perfectly in line.
No worries about the used belt, It's still good and don't need to be replaced.
Often linked posts:
Going small with MMU2
Real Multi Material
My prints on Instagram
Opublikowany : 15/03/2018 5:09 pm
