Big part Bed temp
Philippe Trottier
(@philippe-trottier)
Big part Bed temp
I have a big(ish) part flat side is 22cm x 18cm x 5 cm high.
I had the bed at 55C and it often lifts up with a loud clunk. Would it be better to:
- make the bed 60C
- start at 50 or 55C then go up to on layer 2 or 3 60C to prevent the plastic to look flatten.
- Apply glue to the PEI sheet and hope it stays ...
Postato : 20/09/2016 2:02 am
David T.
(@david-t)
Re: Big part Bed temp
What material?
Postato : 20/09/2016 8:51 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Philippe
For PLA I use 60 degrees bed temp all the time and for larger parts 65 degrees. No lifting.
Peter
Postato : 20/09/2016 9:51 am
Philippe Trottier
Yes for PLA,
But then do you get the frilled beacon style 1st layer ?
The reason I usually do the base , 1st layer, at 55C, then crank it up.
Postato : 20/09/2016 1:49 pm
PJR
 PJR
(@pjr)
Philippe
I do not get any issues with the first layer, even at 65 degrees.
Peter
EDIT: Do you mean "fried bacon"??? Only get that if the nozzle is too low...
Postato : 20/09/2016 3:35 pm
Ben
 Ben
(@ben)
also get some brim on to help stop it lifting. 🙂
Postato : 20/09/2016 3:47 pm
