Big part Bed temp
I have a big(ish) part flat side is 22cm x 18cm x 5 cm high.
I had the bed at 55C and it often lifts up with a loud clunk. Would it be better to:
- make the bed 60C
- start at 50 or 55C then go up to on layer 2 or 3 60C to prevent the plastic to look flatten.
- Apply glue to the PEI sheet and hope it stays ...
Re: Big part Bed temp
What material?
Philippe
For PLA I use 60 degrees bed temp all the time and for larger parts 65 degrees. No lifting.
Peter
Yes for PLA,
   But then do you get the frilled beacon style 1st layer ?
The reason I usually do the base , 1st layer, at 55C, then crank it up.
Philippe
I do not get any issues with the first layer, even at 65 degrees.
Peter
EDIT: Do you mean "fried bacon"??? Only get that if the nozzle is too low...
also get some brim on to help stop it lifting. 🙂
