Bed Error Min Temp and SD card shows 15% done
gerald.b3
(@gerald-b3)
I just received my Prusa i3 MK2 yesterday, and after a long assembly I was delighted to see that everything worked fine after I put it together.
After a day of printing everything was still working fine, so I decided to move the printer from where I assembled it to its permanent home in my room.
I moved it very carefully how it showed me to in the manual and I never hit it on anything, but after I moved it I decided to run the calibration again to make sure everything was level. After I did this (The calibration said everything looked good) I tried to do the V2Calibration, but when I tried to print it it gave me the error "Bed Min temp" and the LCD told me the SD was at 15% done (Even though nothing had printed). In the selftest the printer said the bed was fine, and the bed did heat up, so I don't know what the problem is. I searched on the internet for similar problems and I didn't come across anything.
The attached video is what happens when I try to print the V2Calibration (The squeaking on the Z axis is something I need to fix, but it doesn't affect the print at all)
Any help is appreciated
Napsal : 24/06/2017 12:52 am
