Alternative source for the orange ABS
cristian.s
(@cristian-s)
I want to print a replacement Y belt holder(new model) but I'd rather use the same orange ABS which is now out of stock in the shop.
Does anyone know an alternative source for that filament?
Opublikowany : 09/08/2016 9:09 pm
Cipis
(@cipis)
Re: Alternative source for the orange ABS
Make it black :-).
I doubt you can find alternative source of that filament.
Opublikowany : 09/08/2016 10:00 pm
3Delight
(@3delight)
Moderator Moderator
Have you tried Amazon? I don't know which country you're in but the UK one has these for example:
https://www.amazon.co.uk/dp/B00J4GXNZK/
https://www.amazon.co.uk/dp/B01CP5DKXQ/
https://www.amazon.co.uk/dp/B00J0H4EVU/
Search: https://www.amazon.co.uk/s/url=search-alias%3Daps&field-keywords=orange+abs
The USA site is similar:
https://www.amazon.com/s/url=search-alias%3Daps&field-keywords=orange+abs
Josef said that the Prusa filament is made in Czechoslovakia but whether it is available to buy direct from the makers I don't know...
Opublikowany : 09/08/2016 10:34 pm
richard.l
(@richard-l)
Member Moderator
While I understand the desire to have it the same color but since it is a hidden part I would use whatever I had available.
Opublikowany : 10/08/2016 2:15 am
cristian.s
(@cristian-s)
Yeah, you're probably right.
I think I will make it from PLA. How high would you recommend the infill to be for such a part?
Thank you.
Opublikowany : 10/08/2016 6:30 am
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
I would not recommend PLA for such parts under stress. My experience with a printed toy catapult indicates, that the PLA flows under long constant stress and a bit higher than room temperature. The catapult loaded with thin rubber bands bent visibly in a summer heat (roughly 30 degrees centigrade) after a couple of days.
Vojtech
Opublikowany : 10/08/2016 9:20 am
richard.l
(@richard-l)
Member Moderator
Cristian
Vojtech is right. Since it is attached to the heated bed it would be best to use either ABS or PETG.
Opublikowany : 10/08/2016 4:02 pm
hathawsh
(@hathawsh)
If you're in the USA, use Makergeeks. They make low odor, medical grade ABS for a decent price.
http://www.makergeeks.com/mafiabs1orkr.html
Opublikowany : 11/08/2016 8:37 am
cristian.s
(@cristian-s)
Cool. Unfortunately i am in Europe.
They will probably bring it back in the shop soon-ish.
For now I am looking for black ABS.
Opublikowany : 11/08/2016 9:50 am
Rutilate
(@rutilate)
If you're in Europe, can you order directly from e3d-online?
http://e3d-online.com/All-Filament/SpoolWorks-PLA-Sweet-Orange17
It is only 750g rather than 1kg for some reason.
Opublikowany : 11/08/2016 8:15 pm
Slightly off target...
I have ordered orange PLA off five different vendors on eBay. And so far. All have been unable to supply... do you think Josef has monopolised all of the orange dye in the northern hemisphere?
Joan
Opublikowany : 12/08/2016 6:46 pm
jeff.c
(@jeff-c)
I just printed anti-vibration feet for my newly-assembled i3 Mk2 in Zortrax's Z-ABS orange and it's a pretty good match. You probably don't have this in stock either but might know someone who does. Or, Amazon sells it for US $29.90 with free USA shipping.
Opublikowany : 13/08/2016 11:28 pm
3Delight
(@3delight)
Moderator Moderator
Joan
Probably... have you seen their print farm?! 😆
For a minute there I thought you'd typed Zordrak's Z-ABS orange!! ( )
Opublikowany : 13/08/2016 11:44 pm
Jens
 Jens
(@jens-5)
I have designed and printed a replacement for the Spool Holder. The material is http://www.filafarm.de/products/abs-filament color orange and it fits reasonably.
[attachment=0]20160814_135752[1].jpg[/attachment]
Opublikowany : 14/08/2016 2:33 pm
