Y-Splitter metal tube out of alignment?
Quintesse
(@quintesse)
I've assembled the Y-Splitter according to the instructions but one of the metal tubes is really off-center
If I remove the tube it seems the hole isn't really round:
I can make filamente enter it only with difficulty. Perhaps this is something I could do myself, but I don't have any tools this small. What would I need? Some kind if teensy file? Any other ideas?
But even so, the instructions say "make sure filament can pass into the PTFE tube without any resistance" ( http://manual.prusa3d.com/Guide/Multiplexer/374#s6206 ) . The other tubes etc seem okay, but I can't say filament enters "without any resistance". There is a definite drag when it passes through the metal tube and I definitely notice a bump (not like an obstacle, just a sharp increase in drag) when it enters the PTFE tube. Are the instructions correct and there's something wrong with my assembly or is the "without any resistance" a bit of an exaggeration?
Respondido : 30/08/2017 8:28 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Y-Splitter metal tube out of alignment?
The top of the tube should move around and self-centre.
Of not there is possibly a piece of plastic swarf preventing that happening. Try to carefully clean out the printed part.
Peter
Respondido : 30/08/2017 9:46 pm
Quintesse
(@quintesse)
No, it doesn't budge at all. It's very snug unlike the others that have some wiggle room.
Thing is I don't think I have anything so small to try to smooth any excess material. Unless it would be to try to break it away. But I'm a bit hesitant doing that with the inside of the Y-splitter 😉
I'll go to a hardware store tomorrow and see if they have like a _very_ fine file or something,
Respondido : 30/08/2017 9:52 pm
PJR
 PJR
(@pjr)
You could try a 1.8mm drill bit, by hand twisting slowly as you lower it.
Peter
Respondido : 30/08/2017 9:59 pm
richard.l
(@richard-l)
Miembro Moderator
Tako,
See if you can find a set similar to this at your local hardware store. They may not be the best file set but they do work extremely well for our purpose.
https://www.amazon.com/Piece-Precision-Needle-File-Set/dp/B006N3EPKE/ref=sr_1_4?ie=UTF8&qid=1504124140&sr=8-4&keywords=precision+file+set
Respondido : 30/08/2017 10:18 pm
Quintesse
(@quintesse)
@PJR: This was actually a very good idea. Thanks.
I didn't need (nor do I have) a 1.8mm drill bit, but the obstruction was higher up in the Y-splitter where a 3mm drill bit enters easily and with that I was able to smoothen out the walls. The filament enters much more smoothly now.(There's still some difference between the 4, but it's much better in general).
@richard: that seems like a good idea yes 🙂
Respondido : 30/08/2017 10:46 pm
