Single Material Prints Leave filament in hot end
After doing a single material print on my I3 MM it will leave the filament used in the hot end, not retracted into its tube, so if I try to do another print that uses a different material it will be unable to extrude anything because the previous material is still in the hot end. Is there a fix for this?
Publié : 16/10/2017 7:36 am
Re: Single Material Prints Leave filament in hot end
That's not normal behavior. The ending G-Code script in the slicer should retract it.
Publié : 16/10/2017 12:57 pm
