Simplify3D Multimaterial PROFILE anyone?
bolsoncerrado
(@bolsoncerrado)
Even if it's just for SINGLE FILAMENT mode?
Ideally 4 MM profile, but ANYTHING is welcome! 😉
ThankS!
Postato : 19/09/2017 3:25 pm
bolsoncerrado
(@bolsoncerrado)
Re: Simplify3D Multimaterial PROFILE anyone?
Nothing? Nada? Niente? Rien?
Postato : 22/09/2017 11:04 pm
I haven't used S3d much since I got the MMU, I use Kiss and Slic3r.
Postato : 23/09/2017 12:47 am
PJR
 PJR
(@pjr)
Antient Member Moderator
OK, for single filament printing, it should simply be a matter of replicating the start and end G-code from a Slic3r slice.
For multiple filament printing... Well, I have written a post-processor for KISS. I have also looked at S3D G-code after having been asked to create a post-processor for S3D. What I saw was horrendous/nonsensical G-Code; I simply wasn't prepared to invest the huge amount of time required to untangle it - if it would have been possible. The only solution would be to find a programmer who has that time. Or move to a decent slicer (Slic3r or KISS).
Peter
Postato : 23/09/2017 10:06 pm
Laird Popkin
(@laird-popkin)
Rather than writing a post-processor, which seems like it would be fragile/difficult is the Goode required for MMU to work be configured into S3D’s code generation (e.g. Level change, etc.).
Postato : 26/09/2017 4:54 am
PJR
 PJR
(@pjr)
I thought about that almost a year ago. Then I realised it's not that simple, hence the post-processor.
Peter
Postato : 26/09/2017 9:31 am
richard.l
(@richard-l)
Utenti Moderator
A post processor either needs to be incorporated in the slicer, i.e. Slic3r PE, or a separate post processor needs to be written for the slicer like Peter has done for KISS. The waste tower has to be large enough to handle the max number of filament changes on any given layer in the print, plus on those layers where there is no filament change the waste tower only needs minimal infill and doing this based just on layer change would be impossible.
Postato : 26/09/2017 7:56 pm
PJR
 PJR
(@pjr)
It's actually a lot more difficult than this. Location of tower, layer height and purging volumes all add to the complexity. Plus the layer before a layer change, the sparse infill needs to be semi-sparse. Then there's getting the speeds correct for each material type. And a few other things.
Peter
Postato : 26/09/2017 8:05 pm
richard.l
(@richard-l)
Utenti Moderator
Peter
Absolutely. I was just giving the shortened, easy to understand version. 😀
Postato : 27/09/2017 6:43 pm
Laird Popkin
(@laird-popkin)
Thanks for the explanations, guys. Makes sense.
Postato : 28/10/2017 4:36 am
