Retract on print cancellation?
I would like to get the active extruder reset after a print is cancelled (through octoprint). Would it be sufficient to include the major retractions:
G1 E-15.0000 F5000
G1 E-50.0000 F5400
G1 E-15.0000 F3000
G1 E-12.0000 F2000
as part of the cancellation, or would I also need to include the incremental extrusion/retractions I see get generated in the gcode:
G1 X180.250 E3.0000 F1600
G1 X239.750 E-5.0000
G1 X180.250 E5.0000 F2000
G1 X180.250 E5.0000 F2400
G1 X180.250 E5.0000
G1 X239.750 E-3.0000
Napsal : 04/11/2017 2:04 pm
Re: Retract on print cancellation?
I use the gcode from this thread -> https://shop.prusa3d.com/forum/software-f13/octoprint-abort-gcode-for-mm-retraction--t6322.html
works fine. so you can compare it.
Napsal : 04/11/2017 2:39 pm
Topic starter
answered:
Thank you!
Napsal : 04/11/2017 4:23 pm
