Printer not "seeing" other extruder motors after upgrade
brendan.f
(@brendan-f)
Hello all,
I just upgraded my MK2S to the 4 material MM and I'm having some issues. The printer isn't picking up the other extruder motors. It's behaving just like it did before the MM upgrade and only using a single extruder. I don't even have the option to load the other materials in the LCD screen. I've checked these items:
-Wiring is correct and fully plugged in
-Green light on multiplexer board is on
-Latest firmware is installed
It was built it as a single material printer last week, so I have the latest firmware (I also downloaded all the MM software when I downloaded the driver package cause I knew I would be upgrading shortly) but I haven't altered or edited the firmware in any way. Is there something I need to do to turn the MM part on?
Thanks all in advance!
Postato : 07/10/2017 4:19 am
AJS
 AJS
(@ajs)
Re: Printer not "seeing" other extruder motors after upgrade
You do not have a MMU version of the firmware installed. Re-flash the firmware and make sure you pick the MMU version.
Postato : 07/10/2017 6:06 pm
