Ordering MK2S & MM upgrade - come assembled?
Bytor
(@bytor)
If I order the pre-assembled MK2S AND the Multi-Material kit together, will the Multi-Material be assembled with the main printer or will I need to install the MM kit myself?
- 1st "printer" TIKO 3D
- 2nd PRUSA i3 MK2S with MMU v1
- 3rd PRUSA i3 MK2S
- 4th PRUSA i3 MK3 with MMU v2- 5th PRUSA i3 MK4 (upgraded from MK3) with MMU v3 (upgraded from…
Veröffentlicht : 08/06/2017 3:48 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Ordering MK2S & MM upgrade - come assembled?
I believe that at the moment you will have to install the MM upgrade yourself.
Peter
Veröffentlicht : 08/06/2017 4:18 pm
Jakub Dolezal
(@jakub-dolezal)
Mitglied Admin
Hi Scott,
for now, Multi Material kit is shipped in parts and you have to assemble it yourself. If this is your first Prusa printer, I recommend to use MK2S first, learn basics of 3D printing and then upgrade to the next level, which is Multi Material.
Assembly manuals
/ Knowledge Base
Veröffentlicht : 10/06/2017 10:08 pm
