Multiplexer not multiplexing?
Vernon Draper
(@vernon-draper)
Anyone,
I just did the multi-upgrade on an MK2S. When I go to load filament from the control screen, I can choose any one of the loaders. However, no matter which I choose, the loader #1 motor runs. I am meticulous but I could have made a mistake. I have reloaded the firmware 3 times and I have remade all my connections 3 times. It's as though the multiplexer board doesn't multiplex. I was very careful not to touch the board chips and to make sure I was well grounded.
What to try now?
Vernon
Vernon Draper
Napsal : 12/09/2017 6:02 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Multiplexer not multiplexing?
Which firmware version have you loaded?
Are you sure you have connected to the correct pins on the RAMBo P3 header?
Peter
Napsal : 12/09/2017 11:11 pm
AJS
 AJS
(@ajs)
This happened to me also. The issue was that I had connected the control lines to the MUX incorrectly on the RAMBO board. I was slid over one pin.
Please check that the multiplexer connection (Not the extruder) is connected correctly. That fixed it for me.
Napsal : 15/09/2017 4:19 am
Vernon Draper
(@vernon-draper)
I checked my firmware 3 times. I checked my connections 3 times. Out of frustration I unplugged everything and started over a week later. Magically, it works now! 😯
I must have had something plugged in wrong, after all. Thank you to all who responded to help.
Vernon Draper
Vernon Draper
Napsal : 17/09/2017 7:07 pm
