Multiplexer I/O cable missing
Well, I got my upgrade kit and it was missing the I/O cable for the multiplexer. So I made my own. It took me a little while to figure out so I figured I would post and save anyone else the time.
Happy MM Printing! 😀
The manual only shows where the red wire goes. here is the picture from the manual with all the remaining wire colors on pins 1-4.
would have been easier if it was just a straight cable. but pins 2,3,4 are reversed. Had to look at the source code of the firmware to figure that out 😕
#ifdef SNMM
snmm_extruder = tmp_extruder;
st_synchronize();
delay(100);
disable_e0();
disable_e1();
disable_e2();
pinMode(E_MUX0_PIN, OUTPUT);
pinMode(E_MUX1_PIN, OUTPUT);
pinMode(E_MUX2_PIN, OUTPUT);
delay(100);
SERIAL_ECHO_START;
SERIAL_ECHO("T:");
SERIAL_ECHOLN((int)tmp_extruder);
switch (tmp_extruder) {
case 1:
WRITE(E_MUX0_PIN, HIGH);
WRITE(E_MUX1_PIN, LOW);
WRITE(E_MUX2_PIN, LOW);
break;
case 2:
WRITE(E_MUX0_PIN, LOW);
WRITE(E_MUX1_PIN, HIGH);
break;
case 3:
break;
default:
break;
Re: Multiplexer I/O cable missing
Hi Roy.e,
We will update this part of the manual with a new photo soon.
Regarding the cables, please contact the support at [email protected]
Already did. Thanks!
