[Zamknięte] MMU the steel tubes is necessary?
gandhi.c
(@gandhi-c)
Are the metal tubes inside the quick connectors really necessary?
I ask this question because I just installed the MMU in the prusa, but I feel that these metal tubes are too narrow for the filament, so you could work without them or they really are very important.
Thank you.
Opublikowany : 12/01/2018 3:36 am
patryk.c2
(@patryk-c2)
Re: MMU the steel tubes is necessary?
have a look at this post https://shop.prusa3d.com/forum/original-prusa-i3-mk2-multi-material-f26/monoplexer-and-multiplexer-redesigns-no-metal-part-t12801.html
Opublikowany : 14/01/2018 11:08 pm
seth.g2
(@seth-g2)
As far as i can tell they are not necessary. I've had tons of prints with higher quality without them.
Someone beat me to my own topic lol.
Opublikowany : 14/01/2018 11:56 pm
supermerill
(@supermerill)
If the steel tube is too narrow, the filament may not be able to enter the ptfe. My advice : get a better filament, because if that one don't have a (almost) regular 1.75mm diameter you will encounter many problems with it. The mmu isn't forgiving with bad filament.
Opublikowany : 15/01/2018 7:03 pm
