MM Post Processor Changing gcode Temp
Eric
 Eric
(@eric-5)
Is there any reason why the PostProcessor program is changing the temp after the first layer? The PP changes the M104 command from S205 as set in Slic3r to S15. I have to edit the gcode after I run a gcode through the program. This only happens at the beginning of the second layer.
I can't find anywhere in the MM PP program or related files to change this behavior.
Thanks.
Publié : 27/10/2017 2:34 pm
richard.l
(@richard-l)
Membre Moderator
Re: MM Post Processor Changing gcode Temp
Thanks.
Check your filament settings in Slic3r.
Publié : 27/10/2017 3:40 pm
Eric
 Eric
(@eric-5)
Checked before I posted.
I think this has to do with the fact I'm using the post processor after Slic3r. Maybe I shouldn't be using the post processor at all. Is that only for non-slic3r gcodes?
Publié : 27/10/2017 4:59 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
The post processor is no longer used. It was created for use before Slic3r included the purge tower.
Peter
Publié : 27/10/2017 5:19 pm
Jakub Dolezal
(@jakub-dolezal)
Membre Admin
MM post-processor was used in the very beginning, now it is part of Slic3r PE and I recommend to use it instead. Newest Slic3r PE also allows to place the wipe tower.
Assembly manuals
/ Knowledge Base
Publié : 29/10/2017 12:57 pm
DaveinMI
(@daveinmi)
I thought we have to use the MM Post Processor after using Color Print ?
Publié : 30/10/2017 5:14 pm
PJR
 PJR
(@pjr)
No, not at all.
ColourPrint simply allows a filament change in the same extruder; you don't need a tower for that.
Peter
Publié : 30/10/2017 9:35 pm
Cipis
(@cipis)
Membre
Well, post-processor is actually still used for processing g-code from colorprint (you can select to which extruder printer will switch so you need wipe tower for that).
See manual:
Publié : 30/10/2017 10:23 pm
PJR
 PJR
(@pjr)
Well, that just shows how much I don't know.
Thanks Roman!
Peter
Publié : 30/10/2017 10:48 pm
DaveinMI
(@daveinmi)
I've tried the ColorPrint three times, still can't get it to do what I want it to do. I want extruder 1 until 2.0 mm then change to extruder 2. Sometimes it starts with 1, sometimes it starts with 2.
Publié : 31/10/2017 10:14 pm
