Live Z on MMU
AJS
 AJS
(@ajs)
Live Z on MMU
I will be shortly doing my MMU upgrade, but have become dependent on Jeff's wonderful method of setting Live Z.
Is there a MMU version of:
calibration_surface_PLA_75x75@200um_v4.gcode
Originally found here:
http://shop.prusa3d.com/forum/prusa-i3-kit-building-calibrating-first-print-main-f6/life-adjust-z-my-way-t2981-s30.html#p26853
Thanks in advance.
Veröffentlicht : 28/08/2017 2:19 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Live Z on MMU
Easy enough to slice yourself.
I have always used 9 small squares.
Peter
Veröffentlicht : 28/08/2017 8:45 am
