Live Z on MMU
I will be shortly doing my MMU upgrade, but have become dependent on Jeff's wonderful method of setting Live Z.
Is there a MMU version of:
calibration_surface_PLA_75x75@200um_v4.gcode
Originally found here:
Thanks in advance.
Napsal : 28/08/2017 2:19 am
Re: Live Z on MMU
Easy enough to slice yourself.
I have always used 9 small squares.
Peter
Napsal : 28/08/2017 8:45 am
