How do you print selective soluble supports?
roy.e
(@roy-e)
Anyone know how to slice the selective soluble supports Mr. Prusa was showing off in one of the updates.
http://www.prusaprinters.org/update-multimaterial-upgrade/
Opublikowany : 29/05/2017 2:30 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: How do you print selective soluble supports?
Print Settings/Multiple Extruders
Set Support Material to a regular filament and interface extruder to the PVA extruder.
Peter
Opublikowany : 29/05/2017 7:55 am
roy.e
(@roy-e)
Got it! thanks!
Opublikowany : 29/05/2017 6:38 pm
Vojtěch Bubník
(@vojtech-bubnik)
Member Admin
Printing selective supports (soluble interface, non-soluble base) is not supported yet as there is a single XY gap applied for both, but a different value is needed for the selective support: Nearly zero XY gap for soluble interfaces and the usual gap for the non-soluble base. As of now you need to set the XY separation to the value normally used for non-soluble support.
Opublikowany : 30/05/2017 9:07 am
PJR
 PJR
(@pjr)
Incorrect info
Opublikowany : 30/05/2017 9:53 am
