enclosure space with MMU?
Chris Abbey
(@chris-abbey)
Howdy folks, could someone that has the MMU already installed please run the Z axis all the way up and measure how far above the table surface the bowden tubes reach? I'm working to build an enclosure for my MK2S and want to ensure I have enough room for the MMU when I eventually get it. Thanks!
Respondido : 19/11/2017 8:23 am
fasteddy
(@fasteddy)
Re: enclosure space with MMU?
From table surface to the top of the bowden tube “arches” with the z-axis all the way up is 22 inches.
Respondido : 20/11/2017 12:38 pm
ir_fuel
(@ir_fuel)
I measured at 55cm. Seems to correspond to the above post.
I'm going to build an enclosure myself but will relocate the extruders so I can feed the filament from the top without having to bend it all the way back up again.
Respondido : 20/11/2017 8:39 pm
Chris Abbey
(@chris-abbey)
Thank you both! That's way taller than I expected.
Respondido : 20/11/2017 9:12 pm
