Deformed PTFE liner tip and removal trick
roy.e
(@roy-e)
If your MM upgrade has gone anything like mine has you have had a few jams.
I have taken the PTFE liner out a few too many times and I managed to deform the top half a little bit. This was adding some lag to my retracts.
So to fix it I stuck in a 2mm ball end wrench about half way through and twisted it around a few times to round out the top half again. now its smooth retraction again.
Now if I have to remove it again. i insert the wrench first, depress the release and pull it out.
I know its not exactly Ideal, But I don't have any of this fancy high precision PTFE liner lying around to just replace it with and it still mates with the heat break fine. I think Prusa should consider including a spare.
If anyone has any better ideas or a way to remove the tube without deforming it, I would love to hear it.
Happy MM Printing 😀
Posted : 29/05/2017 3:39 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: Deformed PTFE liner tip and removal trick
I don't understand what is causing your problem which requires the PTFE removing, but FWIW when I need to remove it, I use round nose pliers when it's too tight to remove by hand.
However, I have found that unscrewing the heat break half a turn, inserting and locking the PTFE tube then tightening the heat break helps ensure there is no gap between the two where soft filament can get stuck.
Peter
Posted : 29/05/2017 8:01 am
roy.e
(@roy-e)
pushing down too hard to clear a jam and breaking the filament so its flush with PTFE liner 😳
thanks for the tip
Posted : 29/05/2017 6:50 pm
