Color Print with MMU
DaveinMI
(@daveinmi)
Hello, I want to print with extruder 1 until 1.8 mm, then change to extruder 2 for the rest of the model. I sliced the model in slic3r mm, exported gcode and imported it to ColorPrint. Set the slider scale to 1.8 mm, selected extruder 2, and exported the gcode. Then I imported the gcode file into the MultiMaterial Post Proccesor, exported it and used that gcode file to print with. It printed the whole model from extruder 2. Where did I goof up ?
Thanks !
Opublikowany : 27/10/2017 3:13 pm
DaveinMI
(@daveinmi)
Re: Color Print with MMU
I continue to try to use ColorPrint with my MMU, but now I see a new problem. When it prints the wipe tower at a color change the Z height stays the same. So if the Z is at 20 mm when the color change takes place, filament is just extruded into the air, and the print head wants to drag it back to the print in process.
Opublikowany : 30/10/2017 5:18 pm
