MMU kit: Can't remove old pulley.
DDubyah
(@ddubyah)
Hi there. I've got a factory assembled mk2, and i'm trying to fit the multi material upgrade kit. I'm on the step "3.2 The Extruder Assembly: removing the old pully". But the socket of the grub screw seems to be stripped, so i can't unscrew it to remove the pulley! I've tried several 1.5mm allen keys but they're all turning freely in the grub screw socket.
Aaarg! How do i get past this? Every time i sit down to try to fit this kit i'm hitting a really frustrating problem. Any help would be greatly appreciated.
Opublikowany : 27/10/2017 5:01 pm
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: MMU kit: Can't remove old pulley.
A factory assembled unit may have Loctite on the screw.
You may need to cut a slot in the top so you can undo with a screwdriver. You could also apply a little heat, but be careful as you could damage the motor.
Peter
Opublikowany : 27/10/2017 5:21 pm
DDubyah
(@ddubyah)
Hmm, good thinking - I’ll see if I’m brave enough to cut a slot in it with my dremmel.
Opublikowany : 27/10/2017 6:03 pm
DDubyah
(@ddubyah)
Peter
Using a soldering iron should be ok to apply a little heat to it, right? Figure it’s more local than a heat gun. What you think?
Opublikowany : 27/10/2017 9:44 pm
PJR
 PJR
(@pjr)
Peter
There's a big lump of brass there; I don't think a soldering iron will be effective, but it's certainly worth a try.
Peter
Opublikowany : 27/10/2017 10:47 pm
karel.k
(@karel-k)
Had the same problem. I ended up with drilling out the grub screw with 2mm dril.
Opublikowany : 30/10/2017 9:06 am
DDubyah
(@ddubyah)
That’s plan B I guess. I’ve just bought some “screw extractor” bits, so going to give that a go. Did you manage to salvage the pulley?
Opublikowany : 31/10/2017 10:53 pm
DDubyah
(@ddubyah)
QA factory assembled unit may have Loctite on the screw.
Peter
Worked a treat, thanks. Cut a slot in the top with a dremel, used a screw driver to get the grub screw out. Had to use a heat gun to apply a little heat to the pulley to get it off the shaft. No Loctite, thankfully. I’m back in business. Yay!
https://imgur.com/a/VKouE
Opublikowany : 02/11/2017 12:11 am
