3D labprint STL files to be converted into MMU gcode
[Closed] 3D labprint STL files to be converted into MMU gcode
Harald
(@harald-3)
Hi there,
I have recently purchased the STL files for the Piper Pawnee and have started the build. The delivered G-code is not usable with the MMU version as far as I can see.
Slicing settings for the PRUSA slic3R are not clear either, and I wonder if any of you is working on a similar project. It would be great to understand what kind of settings you have chosen and what kind of print quality you get out of your printer. I am mainly struggling with the weight of the fuselage and wing pieces, as thin wall printing, infill settings, perimeter settings etc are not that clear.
In parallel I have analysed the CURA settings but did not manage to get much further either.
Thanks a lot for any help,
BR, Harald
Napsal : 09/02/2018 9:22 am
