Linear Advance for an MK2 PrusaSlicer 2.3.1 Profile?
ProtoPix
(@protopix)
When I select the MK2S profile in PrusaSlicer 2.3.1, I'm seeing Linear Advance options for Print Settings.
I've noted that "with firmware 3.9.0, we introduced Linear Advance 1.5 for the Original Prusa MK3S, MK3, MK2.5S, and MK2.5."
Is Linear Advance (1.0) available in the MK2S 3.2.3 firmware or is the MK2S profile in PrusaSlicer 2.3.1 incorrect?L
Napsal : 29/04/2021 2:01 pm
Robin
(@robin)
RE: Linear Advance for an MK2 PrusaSlicer 2.3.1 Profile?
Linear Advance was reactivated with 3.2.0  ( https://github.com/prusa3d/Prusa-Firmware/releases/tag/v3.2.0 )
Napsal : 02/05/2021 1:41 pm
Cipis
(@cipis)
It is just the name of faster print profile, which was created to showcase benefits of linear advance back in the day. LA is basically always used (based on the M900 command in the filament settings), no matter which print profile is used.
MK2S firmware supports older Linear Advance 1.0 only.
Napsal : 03/05/2021 8:01 pm
