G-Code Issue
corey.a
(@corey-a)
G-Code Issue
I now have an AC powered heat bed and need to turn the bed off while auto leveling. While I have figured that out, I still am setting the bed temp thru the G-Code with "M190 S60". I would like to pull the temp data from the .gcode file so the when the bed is turned back on, the temp is correct for which ever material I am printing. Here is my current code:
M75; Start Timer and Engage Filament Monitor
M190 S75; wait for bed temperature
M140 S0; turn off heat bed
G28 ; home all axes
G29 ; auto level
M190 S60; wait for bed temperature
G4 S10; wait for heaters to recover
G1 X0 Y20 Z0.2 F3000 ; get ready to prime
G92 E0 ; reset extrusion distance
G1 F200 E25 ; extrude filament
G92 E0 ; reset extrusion distance again
M420 Z1 ; fade ABL off after 1mm
Thanks in advance!!!
Postato : 06/06/2018 4:11 am
PJR
 PJR
(@pjr)
Antient Member Moderator
Re: G-Code Issue
Depending on the slicer used:
Slic3r:
M190 S[first_layer_bed_temperature]
KISS:
M190 S<BED>
Peter
Postato : 06/06/2018 9:34 am
corey.a
(@corey-a)
Re: G-Code Issue
Thanks Peter,
Would you happen to know the syntax for Cura by chance. Or, where to find it.
Regards, Corey
Postato : 08/06/2018 4:50 am
PJR
 PJR
(@pjr)
Re: G-Code Issue
I only have Cura 15.04.6 on my PCs (just to have a quick look at models)
The token in that is:
M190 S{print_bed_temperature}
Peter
Postato : 08/06/2018 10:23 am
corey.a
(@corey-a)
Re: G-Code Issue
Thanks again.
I have Cura 3.3.1 and managed to find some syntax that worked: M190 S{material_bed_temperature};
Yours may work as well though.
Regards, Corey
Postato : 08/06/2018 5:42 pm
