Bad Pinda Probe?
Joel Buckingham
(@joel-buckingham)
Bad Pinda Probe?
I've having issues with my Pinda Probe detecting anything. After fixing a blocked heat break I had run at least a half dozen prints without any issue. Then it just stopped detecting the bed. Whenever I try to auto-home it keeps going and pushes the bed down a couple mm and I have to hit reset or the power. I don't see the led light up regardless of what I do. I tried following the trouble-shooting steps suggested in this thread:
https://shop.prusa3d.com/forum/hardware-firmware-and-software-help-f59/pinda-wire-disconnected-unplugged--t14694.html
But the light is always of. I've tried:
  • moving the wire and wiring harness to reconnect any small breaks in the wire
  • moving the bed left and right, up and down
  • placing metal tools under the probe end
  • loosening and re-positioning the probe
  • wiggling, disconnecting, and reconnecting the connection at the main board
  • I'm not seeing anything that even makes the light flicker.
    I'd happily pay for a replacement probe, but I can't find the probe in the Prusa store. Is there anywhere to get a a replacement, or something I can do with my current probe?
    Posted : 07/07/2018 2:28 am
    MechLink
    (@mechlink)
    Re: Bad Pinda Probe?
    here is the link for the probe,
    https://shop.prusa3d.com/en/mk2-spare-parts/127-mk2s-pinda-probe.html
    Also I would contact Prusa via the chat on the store to see if its under warranty or maybe with any further test you could run on it.
    See my stuff at
    https://www.printables.com/@MechLink
    https://www.myminifactory.com/users/MechLink
    Posted : 07/07/2018 4:14 pm
    Joel Buckingham
    (@joel-buckingham)
    Thanks for the link. That's just what I was looking for.
    Posted : 09/07/2018 3:24 am
