The most important links - Original Prusa i3 MK2/S Multi Material
[Épinglé] The most important links - Original Prusa i3 MK2/S Multi Material
Jakub Dolezal
(@jakub-dolezal)
Membre Admin
here is the list of the most important links for your printer:
Please don't use this thread for general questions, create a new thread.
3D Printing Handbook for Multi Material
http://prusa3d.com/downloads/manual/prusa3d_manual_mk2mm_en.pdf
Multi Material upgrade manual
http://manual.prusa3d.com/c/Original_Prusa_i3_MK2_to_Multi_Material_upgrade
Guides how to generate Multi Material G-codes and models
http://manual.prusa3d.com/c/Creating_models
Multi Material troubleshooting
http://manual.prusa3d.com/c/Troubleshooting
Latest drivers including Slic3r PE and PrusaControl:
https://www.prusa3d.com/drivers
Latest firmware:
https://www.prusa3d.com/drivers/#firmware
How to upgrade firmware: link
Printable printer's parts:
https://www.prusa3d.com/prusa-i3-printable-parts/
Recommended print settings are 0.2 mm layer height, infill 20% GRID and material PETG
Printable 3D models:
Models are part of the driver's package
In case you think, something is missing, please let me know below and as always Happy Printing! 😉
Assembly manuals
/ Knowledge Base
Publié : 12/05/2017 6:09 pm
Thebrakshow
(@thebrakshow)
Re: Important Multi Material Links
Can someone please post a link to the multi material stepper motor expansion PCB files? I cant seem to find them anywhere. Thanks!
Publié : 17/10/2017 9:28 pm
Re: The most important links - Original Prusa i3 MK2/S Multi Material
Thanks Jakub
Regards Joan
Publié : 03/05/2018 9:43 pm
Jacques Verreault
(@jacques-verreault)
Original Prusa i3 MK2/S Multi Material .... Maxtemp error
Hi everyone ... my name is Jacques
I have a problem with my MK2/s MMU 1.0 ... I have a maxtemp error and a high pitch sound. I've check all the wiring and all seem ok ... I need help. Has anyone had that problem before. Thank you.
Publié : 27/08/2021 9:31 pm
Hi Jacques,
Mintemp either indicates a temperature below 15C, or a broken thermistor/thermistor wire, or a disconnection
most often one of the wires breaks.
does your LCD show 0C for either the extruder or the heatbed? that will give you a clue as to which thermistor circuit is defective.
you can replace the wires with 22AWG flexible silicone wires, regards Joan
Publié : 27/08/2021 9:47 pm
bjwilson
(@bjwilson)
I think that these links are much more important - Vertex MMU2S parts
https://www.prusaprinters.org/prints/69054-vertex3dorg-mmu2s-extruder-unit
https://github.com/Vertex3dPrinters/VERTEX-MMU2S-PLUS
I was literally using my MMU2S as a doorstop, but then I printed the modified Vertex parts and rebuilt my MMU2S and extruder with them (no more chimney!). The unit now works almost flawlessly. It's magical to watch when it's working. I'd never gotten to see it go past about 8 tool changes with the original parts.
Publié : 18/12/2021 4:35 pm
Big E
(@big-e)
RE: The most important links - Original Prusa i3 MK2/S Multi Material
How did you vertex extruder mod go? I'm think of going that way too. I've put an 8 way plug/socket in the cables so I can isolate and remove the Mmu2s. Can you use the new vertex extruder without the Mmu2s? That's my idea, so I can remove it completely if it gets annoying 🙂
Cheers,  Eric
Publié : 02/04/2022 5:59 pm
bjwilson
(@bjwilson)
Wow, I missed that there had been a reply. I guess I haven't been here in a while.
I did a similar thing, built sockets into my cables so that I could unplug the MMU2 when it was being stupid, which was all the time. It finally wound up back in the closet. The Vertex extruder, however, was still a good upgrade.
I started printing parts for the MMU3 upgrade (yes, I'm going to try again) and was midway through the extruder parts before I remembered that I didn't want to go back to the chimney. I was hoping maybe it had been redesigned as well but it looks like the same old chimney to me.
Publié : 06/09/2023 12:03 am
Big E
(@big-e)
My experience as well. The MMu2 has been in a box, and I'm printing the parts for the MMU3 - I'm going for the UltiMulti variant. here's hoping ...
Publié : 06/09/2023 11:37 am
