Preheat error when preheating nozzle
Russ
 Russ
(@russ-5)
When doing the self test everything passes when it needs to heat up. However, when I preheat the nozzle to load the PLA filament I get a preheat error. The bed gets to 55/55, but the nozzle temp gets to about 130/215 then the error happens and it starts to cool down. I have checked the connections may times with the same results.
Any suggestions would be appreciative.
Napsal : 16/07/2020 6:22 pm
