MK3 isn't recognizing MMU2 and MMU2 motors won't respond to buttons.
ginger.m
(@ginger-m)
I set up my MMU2 and have everything connected but it's not recognized by the MK3. I also tried to load the filament from the MMU2 but the motors wouldn't move at all. I've tried to find a solution but have so far been unsuccessful. If anyone has any info it would be greatly appreciated.
Publié : 23/07/2020 4:23 am
jsw
 jsw
(@jsw)
RE: MK3 isn't recognizing MMU2 and MMU2 motors won't respond to buttons.
Do you see any light on the MMU?
Does it 'home' when you try to do a filament load?
Publié : 23/07/2020 7:55 am
ginger.m
(@ginger-m)
@jsw
I'm not exactly sure what you mean by 'home' but I tried to load the filament using the buttons on the MMU2 but the selector didn't move at all.
Publié : 23/07/2020 5:26 pm
Have you updated the printer firmware?
If not, it doesn't know the MMU2 exists
there is also MMU2 Firmware to check and update if necessary
Joan
Publié : 23/07/2020 8:08 pm
ginger.m
(@ginger-m)
@joantabb
I updated the firmware on the mk3 and mmu2 and I have reflashed it a couple times based on some troubleshooting tips.
Publié : 23/07/2020 9:05 pm
jsw
 jsw
(@jsw)
Posted by: @ginger-m
@jsw
When you do a filament load to the extruder, the motors will spin to put the large cylinder to the correct position and the selector motor will juke around a bit and then 'home' to the left, and seek the correct filament to load.  I think of this action as a 'yes, it is working' sign.
Publié : 24/07/2020 12:49 am
ginger.m
(@ginger-m)
@jsw
Oh ok so this is actually what I tried to do and the lights worked but the motor never moved.
Publié : 24/07/2020 2:11 am
