Endpoint calibration
Steve-126
(@steve-126)
When I perform a self test, I am having problems with the X/Y endpoint being detected. The extruder is working when it moves toward the endpoint switch it will click or press the switch. I'm pretty sure the wiring is correct. When I use the axis calibration manually, I noticed the X and Y values are always set at 1 (rather than 0). Only when I press on the endpoint switch do they go from 1 to 0. Anyone know what I have done wrong?
Per the document here, https://help.prusa3d.com/article/end-stop-not-hitting_2035
I seem to have the reverse situation, when should be 0 and when switch is pressed it goes to 1. However, I am in the opposite.
Thanks for any insight
Postato : 01/03/2023 3:20 am
