X axis layer shift
Deb
 Deb
(@deb)
X axis layer shift
Can anyone please tell me what is causing this layer shift. It seems sporadic. I can print one fine and the next one might do this. It is not only happening to this one object and is happening to other things I print also. Just like this one...I can print one fine and the next one might layer shift like this too.
Opublikowany : 23/07/2018 4:40 pm
Deb
 Deb
(@deb)
Re: X axis layer shift
Having issues uploading photo...sorry
Opublikowany : 23/07/2018 4:43 pm
BillC
(@billc)
Things to check. Has the bed cable bundle pla stiffener come loose at the bed end or the Rambo so the cables drooped and caught on the y-axis? Did the bed screws catch the Z-Frame? Is the bed hitting a cable tie for the Y axis? Are the Y motor setcrews tight and is one of them on the flat part of the shaft? Is the Y-belt slack enough to jump a few teeth occasionally?
Sporadic faults are very hard to pin down. Good luck.
Bill
Tagaytay City, Philippines
Opublikowany : 23/07/2018 5:05 pm
Deb
 Deb
(@deb)
Thank you! I'll check everything later...it is just so strange.
Opublikowany : 24/07/2018 12:48 am
